anilmisal
Feb 08, 2022Aspirant
WAC510 5ghz Connectivity issue
We are unable connect 5ghz wifi access point. I was upgrade AP Firmware V9.5.5.4.
Sometimes its get connected but at the same time when i try to connecting from other
device its unable to connect. I am trying to change wireless mode. Its working fine with 2.4ghz.
Mode | 11ac |
Channel | Auto (60) |
Channel Width | 20/40/80 MHz |
Clients | 0 (1) |
Traffic | 32.6 GB |
Channel Utilization | 0% |
Hi anilmisal
Looks like you have configured Max wireless client set to 1.
Here is the trace from the logs
Mon Feb 28 11:46:17 IST 2022 nddmp[10970]: alarm : seqNo-[10764], level-[MINOR], info-[Client F8-34-41-BF-0E-DC association denied - Max Client hit]
Please check this configuration and allow the required clients to be connected. See the attached screen shot where you can configure this value.
- anilmisalAspirant
All Laptop are windows 10 had connected another 5GHz router and Some are mobiles.
I will explain one Scenerio.
I am using ASUS X515EA laptop. Sometime it get connected with 5ghz. Sometime its show it could not connect. Same thing happened with other user also. Facing issue with last 15Days. I am also update Firmware for the AP. I had two Same AP another one is working fine.
7 Laptop are same configuration.
Mobile Phone
Oppo F9
Samsung M50
