anilmisal
Feb 08, 2022Aspirant
WAC510 5ghz Connectivity issue
We are unable connect 5ghz wifi access point. I was upgrade AP Firmware V9.5.5.4. Sometimes its get connected but at the same time when i try to connecting from other device its unable to connect. ...
- Mar 01, 2022
Hi anilmisal
Looks like you have configured Max wireless client set to 1.
Here is the trace from the logs
Mon Feb 28 11:46:17 IST 2022 nddmp[10970]: alarm : seqNo-[10764], level-[MINOR], info-[Client F8-34-41-BF-0E-DC association denied - Max Client hit]
Please check this configuration and allow the required clients to be connected. See the attached screen shot where you can configure this value.
