Ricque
Apr 12, 2020Tutor
wac510 disassociations
I'm seeing frequent disassociations of a client. The wac510 is running firmware v8.2.6.7 and the client is served by the 2.4 radio. The client is a raspberry pi running current linux. If the client is inactive for a modest amount of time, the wac510 disassociates it and the carrier is dropped. Usually 2 minutes later, the client reacquires the carrier and the channel re-associated. This repeats about every 6 minutes as long as there isn't network traffic. When there is traffic the disassociation doesn't happen and the client is happy as a clam. I put a ping in a 30 sec loop on the client and didn't see a qlitch all day. I stop the ping and other network use and the disassociations start up. I’ve attached the wac510 log that shows the problem at 12:16:06, 12:22:09 and 12:28:25. This log is uploaded as a pdf, as reqeuired. Let me know if a txt file would be more useful.
I’ve seen similar issues with apparent solutions for other netgear products and am hoping that a solution exists for the wac510.
I want to followup on this discussion in case it’s useful to anyone else. As far as I’m concerned, the issue is resolved and I’d like to thank Raghu for taking this on. Our back-n-forth was done via PM, so the details won’t show up here. Here’s my synopsis:
I have a raspberry pi witth a wifi client experiencing frequent syslog complaints of “wlan0: carrier lost”. Each instance of the error was precipitated by a 802.11 disassociation logged in the WAC510.
Raghu inspected my WAC510 logs and suggested that I turn off Band Steering, which I was using on both 2.5 and 5.0 radios. I turned that feature off and ran a short test and confirmed that the “carrier lost” symptoms were greatly reduced. And I followed up with a 6 hour test and have seen no disassociations.
I consider this solved. Thanks Raghu.
- RicqueTutor
