anilmisal
Feb 08, 2022Aspirant
WAC510 5ghz Connectivity issue
We are unable connect 5ghz wifi access point. I was upgrade AP Firmware V9.5.5.4. Sometimes its get connected but at the same time when i try to connecting from other device its unable to connect. ...
- Mar 01, 2022
Hi anilmisal
Looks like you have configured Max wireless client set to 1.
Here is the trace from the logs
Mon Feb 28 11:46:17 IST 2022 nddmp[10970]: alarm : seqNo-[10764], level-[MINOR], info-[Client F8-34-41-BF-0E-DC association denied - Max Client hit]
Please check this configuration and allow the required clients to be connected. See the attached screen shot where you can configure this value.
anilmisal
Feb 27, 2022Aspirant
Dear Raghu
Please current log where facing same issue.
Mon Feb 28 11:46:42 IST 2022 nddmp[10970]: alarm : seqNo-[10767], level-[OTHER], info-[{"ip":"192.168.0.53","mac":"F8-34-41-BF-0E-DC","hname":"Shubham","txR":"0 Kbps","rxR":"0 Kbps","ssid":"Netweb_AP2","dOs":"Windows OS","dType":"Laptop/PC","mode":"11NG","status":"Authenticated","bssid":"9C-C9-EB-07-83-E0","chnl":"1","chWidth":"20/40 MHz","rssi":"30","state":"QOS/ERP/HT","type":"wpa2","idle":"0","time":"00:00:00","txB":"1689","rxB":"1230","pmf":"none","vlanID":"1","Username":"Not Applicable","radio":"0"}]
Mon Feb 28 11:46:42 IST 2022 nddmp[10970]: alarm : seqNo-[10766], level-[INFO], info-[F8-34-41-BF-0E-DC wireless client connected]
Mon Feb 28 11:46:42 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc WPA: pairwise key handshake completed (RSN)
Mon Feb 28 11:46:42 IST 2022 configd[10699]: 13496: error in fetching sta details for mac = F8-34-41-BF-0E-DC, iface = wifi0vap0
Mon Feb 28 11:46:42 IST 2022 configd[10699]: Authentication Failed for client F8-34-41-BF-0E-DC
Mon Feb 28 11:46:42 IST 2022 configd[10699]: Update IP in FP_DB failed 17992
Mon Feb 28 11:46:42 IST 2022 configd[10699]: Entry [F8-34-41-BF-0E-DC] is already there in list... Update DB..[17986]
Mon Feb 28 11:46:41 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc WPA: received EAPOL-Key frame (4/4 Pairwise)
Mon Feb 28 11:46:41 IST 2022 nddmp[10970]: alarm : seqNo-[10765], level-[INFO], info-[F8-34-41-BF-0E-DC wireless client connected]
Mon Feb 28 11:46:41 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc WPA: sending 3/4 msg of 4-Way Handshake
Mon Feb 28 11:46:41 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc WPA: received EAPOL-Key frame (2/4 Pairwise)
Mon Feb 28 11:46:41 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc WPA: sending 1/4 msg of 4-Way Handshake
Mon Feb 28 11:46:41 IST 2022 hostapd: hostapd_notif_assoc: Marking client's assoc state as 0
Mon Feb 28 11:46:41 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc IEEE 802.11: associated
Mon Feb 28 11:46:39 IST 2022 kernel: [2319968.777477] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:38 IST 2022 kernel: [2319968.249797] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:38 IST 2022 kernel: [2319967.725453] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:37 IST 2022 kernel: [2319967.209564] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:34 IST 2022 kernel: [2319964.341572] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:34 IST 2022 kernel: [2319963.813784] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:33 IST 2022 kernel: [2319963.293035] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:33 IST 2022 kernel: [2319962.772398] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:31 IST 2022 kernel: [2319961.283826] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:31 IST 2022 kernel: [2319960.755496] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:30 IST 2022 kernel: [2319960.238108] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:30 IST 2022 kernel: [2319959.713553] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:27 IST 2022 kernel: [2319956.698616] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:26 IST 2022 kernel: [2319956.167478] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:26 IST 2022 kernel: [2319955.628611] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:25 IST 2022 kernel: [2319955.097665] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:24 IST 2022 kernel: [2319953.639935] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:23 IST 2022 kernel: [2319953.110922] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:23 IST 2022 kernel: [2319952.569508] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:22 IST 2022 kernel: [2319952.025670] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:19 IST 2022 kernel: [2319948.912849] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:18 IST 2022 kernel: [2319948.383666] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:18 IST 2022 kernel: [2319947.850835] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:17 IST 2022 kernel: [2319947.332016] wifi1vap1 Disassociated STA f8:34:41:bf:0e:dc Reason Code 8
Mon Feb 28 11:46:06 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc IEEE 802.11: Station deauthenticated due to reason code 1
Mon Feb 28 11:46:06 IST 2022 nddmp[10970]: alarm : seqNo-[10763], level-[INFO], info-[F8-34-41-BF-0E-DC wireless client disconnected]
Mon Feb 28 11:46:05 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc IEEE 802.11: disconnected
Mon Feb 28 11:46:05 IST 2022 hostapd: wifi0vap0: STA f8:34:41:bf:0e:dc IEEE 802.11: disassociated
Mon Feb 28 11:46:05 IST 2022 kernel: [2319935.414722] ieee80211_mlme_recv_deauth: [wifi0vap0]: Received deauth from f8:34:41:bf:0e:dc with reason 1
Mon Feb 28 11:43:01 IST 2022 nddmp[10970]: alarm : seqNo-[10762], level-[OTHER], info-[{"ip":"192.168.0.57","mac":"C4-23-60-4D-C2-E0","hname":"Suchita-N","txR":"57 Mbps","rxR":"52 Mbps","ssid":"Netweb_AP2","dOs":"Windows OS","dType":"Laptop/PC","mode":"11NG","status":"Authenticated","bssid":"9C-C9-EB-07-83-E0","chnl":"1","chWidth":"20/40 MHz","rssi":"43","state":"QOS/ER
RaghuHR
Mar 01, 2022NETGEAR Expert
Hi anilmisal
