anilmisal
Feb 08, 2022Aspirant
WAC510 5ghz Connectivity issue
We are unable connect 5ghz wifi access point. I was upgrade AP Firmware V9.5.5.4. Sometimes its get connected but at the same time when i try to connecting from other device its unable to connect. ...
- Mar 01, 2022
Hi anilmisal
Looks like you have configured Max wireless client set to 1.
Here is the trace from the logs
Mon Feb 28 11:46:17 IST 2022 nddmp[10970]: alarm : seqNo-[10764], level-[MINOR], info-[Client F8-34-41-BF-0E-DC association denied - Max Client hit]
Please check this configuration and allow the required clients to be connected. See the attached screen shot where you can configure this value.
RaghuHR
Feb 08, 2022NETGEAR Expert
anilmisal what type of device it is? Intel laptops or Android phones or iOS devices? Please give more details of the stations that you are connecting. All devices are not connecting or any specific device is having an issue? Mention model number also.
anilmisal
All Laptop are windows 10 had connected another 5GHz router and Some are mobiles.
I will explain one Scenerio.
I am using ASUS X515EA laptop. Sometime it get connected with 5ghz. Sometime its show it could not connect. Same thing happened with other user also. Facing issue with last 15Days. I am also update Firmware for the AP. I had two Same AP another one is working fine.
7 Laptop are same configuration.
Mobile Phone
Oppo F9
Samsung M50
