Madhu77
Jul 13, 2019Aspirant
BR500 Highly unstable fw version 5.6.0.1
FW Version is 5.6.0.1 On the WAN side, connected to Centurylink fiber optic router On the LAN side, connected to Netgear GC728XP Everything works fine. But only for an hour or so. Then BR500 just ...
Madhu77
Jul 15, 2019Aspirant
I bought it brand new a month ago. I dont recall if I upgraded to 5.6.0.1, or if already had 5.6.0.1
I dont want to do a factory reset and recreate all the IP address reservations, the one VLAN tagging I added, the PPPoE credentials, etc. Can I backup the configuration in 5.6.0.1, and import it into 5.5.0.1?
Is this a problem known to Netgear, is it being resolved?
DaneA
Jul 15, 2019NETGEAR Employee Retired
You may backup the config on the v5.6.0.1 then import it to v5.5.0.1. Observe the internet connection through the BR500 after downgrading the firmware.
As far as I have checked, there is no issue as per described on your initial post pertaining to firmware v5.6.0.1.
DaneA
NETGEAR Community Team
- DaneAAug 01, 2019NETGEAR Employee Retired
As a follow-up on this, let me inform you that a new firmware for the BR500 has been released which is v5.6.0.2. You can download it here. I advise you to upgrade the firmware of your BR500 to the latest firmware version and observe if the same problem occurs.
DaneA
