ComputerMikes
Dec 26, 2018Guide
BR500 Issues and Feedback.
Been looking forward to the BR500 release for some time now and finally just procured one through Powershift Eval.
First impressions:
DHCP Servers and VLAN setup through Insight got my blood ...
ComputerMikes
Dec 31, 2018Guide
Give me an example and I will give it a shot and let you know :)
LegitUser
Dec 31, 2018Aspirant
Hi Mike,
Thanks for being so awesome to help in this, because I could not find it in any documentation online so far!
These are just examples of tests you could do:
Test one:
You have one VLAN and another with an http server running on it. Now add a firewall rule that blocks all traffic.
Check if they indeed can't reach eachother. Then add another rule that only allows HTTP. Check if you can reach the HTTP server.
Test two:
Let's say between 2 VLANs you block all icmp traffic. Ping on clients on VLAN 1 to clients on VLAN 2 should fail from both sides.
Now you only block icmp from VLAN 2 (with pc 1) to VLAN 1 but not in reverse, this should mean the ping request starting from a client on VLAN 1 reaches a client on VLAN 2 (sniffable) but the reply doesn't come back through. Check if this is the case.
These are however just indications of tests. If you know other tests that are easier to check firewall rules with ports in your setup feel free to do so.
Thanks a lot !!!!
Thorwald
- ComputerMikesDec 31, 2018Guide
Might take a bit for me to get around to, but usually that has to do with allowing VLAN interweaving which you can turn on and off between the VLANs. A lot of that also depends on the switches you use, if any.
Right now, I'm only using one LAN port with a bunch of cascaded switches and none of my VLAN traffic is able to see any other VLAN traffic. I have it set that way so that on my one VLAN, that's where all my client machines that have infections get connection to the internet and I can't afford to have them infect the rest of my network. Also, I'm running a bunch of GS110TP switches that support VLAN tagging and routing, so even at the switch level, I am covered.
- LegitUserDec 31, 2018Aspirant
Thanks Mike. A quick ping test would do at this point.
Anyway I started a new thread about this.
https://community.netgear.com/t5/Hardware-VPN-Firewalls-and/BR500-Inter-VLAN-rules/m-p/1683559
