ChristineT
Dec 07, 2021NETGEAR Employee Retired
Nighthawk MR5200 (M5) - We need your feedback!
Good day Nighthawk Community,
I'm reaching out to you today in hopes of soliciting your help. If anyone is experiencing any issues with the Nighthawk MR5200 (M5) Mobile Hotspot we want to hear from you. We have had a very small handful of reports from around the globe of issues with the following:
- Issues connecting to the cellular 4G or 5G network
- Hotspot randomly rebooting
- Cellular/WiFi connection drops randomly
We are unable to replicate any of these issue but take this feedback very seriously. If you're experiencing any of these issues please feel free to post the details by replying to this topic and I'll ensure it gets passed along to our engineering team.
I'm looking forward to hearing from you!
Kind Regards,
Christine
Hi,
maybe it is possible to also help with the issue we experience.
We own two MR5200, let's call one "old" and the other one "new".
We use to run "old" with a Vodafone (Germany) SIM which originally came from a "Vodafone GigaCube", some kind of relabeled HUAWEI 5G Router. This setup was running fine for about 12 Month or so, but recently we started to experience interruptions of LTE connections after 12 to 24 hours. Only a reebot of "old" would help getting reconnected.
So we bought "new", used the very same SIM card with it. We experienced, that "new" wouldn't even connect to LTE nor any other band.
So we ordered a fresh SIM card and used in "new" but experienced the very same behaviour. "new" wouldn't connect to any band.
When using the fresh SIM card in "old", we were back to a connect time of about 12 to 24 hours, but then again interruptions of the connection.
JohnPengcould you take a look at the model.json stats if we upload them?
Many thanks in advance!
Hi Christine.
Really grateful to see this post.
I have a recently purchased MR5100 that receives a "disconnected" overnight on a regular basis. A reboot is needed to restore the service.
This M5 unit replaced a M1 router, but is significantly less reliable (operates 24x7 forhome internet over 4G).
Firmware version NTGX55_12.04.12.00.
Can't see any faciities to access logs, so I have NFI what is going on, but it's frustrating!
PM me for more details. Happy to help diagnose.
Feel free to delete this post.
Cheers.
I recommend starting a new post in regards to your MR5100. This thead is asking for feedback for the MR5200 and user experiences for this model product.
Please start a new forum post in the main Mobile Routers, Hotspots & Modems and we'll try to help you out.
Thank you.
iKaruS_Bungle wrote:
Hi Christine.
Cheers.
- JohnPengNETGEAR Expert
Hi Christine.
Cheers.
Our SE in Australia will contact you and work with you to resolve the issue. Could you please send your contact info to my email: jopeng@netgear.com
Thanks
- ScotchKAspirant
In reply to iKaruS_Bungle I had issues where the MR5100 where kept saying "Mobile Broadband Disconnected". Then through testing we foind oout it was randomly hooked up to another carrier, not my own. Then it would show that it was connected, but when you went to use internet it didnt work. I took it back to the shop and they replaced it.
I have a new device, now one day old, and the 5G has dropped out unexpectedly mid video meeting. My mobile phone with same carrier, stayed connected for me to finish the 2nd half of the meeting.
I will post this in anpther thread for MR5100 as somone has suggested there is a separate thread for that. Cheers.
Could you please let me know which carrier you are using and what is your phone's brand and model?
If possible, please help to capture a model.json file and send it to me via private message.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
- benybaGuide
Hi,
I'm still having 5G unstability issues described in this post :
To summarize, I'm not able to use 5G network since I've upgraded from 10.29.11 firmware. I'm obliged to force it to LTE as 5G connection is highly unstable. Latest FW didn't change anything for me.
Log examples separated by a few seconds :
"connectionText": "5G", "sessDuration": 25636, "sessStartTime": 1318381157, "signalStrength": { "rssi":-79, "rscp":0, "ecio":0, "rsrp":-93, "rsrq":-12, "bars":5, "sinr":1, "end":"" }, "diagInfo": [ { "lteAttached": true, "nr5gAttached": true, "endcEnabledConfig": true, "ltesigValid":true, "ltesigRssi":"-79 dBm", "ltesigRsrp": "-93 dBm", "ltesigRsrq": "-12 dB", "ltesigSnr": "1 dB", "nr5gsigValid": true, "nr5gsigRsrp": "-114 dBm", "nr5gsigRsrq": "-12 dB", "nr5gsigSnr": "15 dB""connectionText": "5G", "sessDuration": 25786, "sessStartTime": 1318381157, "signalStrength": { "rssi":-79, "rscp":0, "ecio":0, "rsrp":-110, "rsrq":-12, "bars":3, "sinr":0, "end":"" }, "diagInfo": [ { "lteAttached": true, "nr5gAttached": true, "endcEnabledConfig": true, "ltesigValid":true, "ltesigRssi":"-79 dBm", "ltesigRsrp": "-110 dBm", "ltesigRsrq": "-13 dB", "ltesigSnr": "0 dB", "nr5gsigValid": true, "nr5gsigRsrp": "-32768 dBm", "nr5gsigRsrq": "-32768 dB", "nr5gsigSnr": "-3276 dB" },{}],Thank you
Benoit
- Flosch77TutorHello from Europe,
I just started research and came across this post. I am using European MR5200 and have big problems connecting to LTE networks. After MR5200 searching for network for several minutes it falls back to WCDMA H+ connection. I can see it cycling through bands B3 B8 B20 before failing. I have German t-mobile contract currently used in Poland, means data roaming. I had chance to crosschange different multi Sims and also use local t-mobile sim. I checked APN settings several times. Phones next to M5 have strong 4g+ connection. Due to roaming I can choose from 4 carriers. One ends up with 4g connection all others fail to connect at all or go to H+ after some time. Regardless of connection type connection is lost after few minutes very often.
I am quite desperate at this point and hope for help.
Regards Florian
edit: I could just check another carriers sim (o2) , same behaviour, no lte, long search for any network. All sims have unlimited 4g/5g plans.- JohnPengNETGEAR Expert
Flosch77 wrote:
Hello from Europe,
Regards Florian
edit: I could just check another carriers sim (o2) , same behaviour, no lte, long search for any network. All sims have unlimited 4g/5g plans.Thanks for reaching out to us. Please see my comments and provide the required information if possible for initial review. Then we will provide instructions to collect more logs if needed.
1. Can you confirm your MR5200 with the T-T-Mo SIM works in Germany, the home network?
2. Since you are in roaming network, please make sure Roaming data is enabled. Please check the check box in front of the roaming data under APN setting
3. For all the SIM cards that can't get on LTE, most likely, it is due to carrier blocking the service to the device
Could you please help to capture the model.json logs with each SIM card you have and send them to me at jopeng@netgear.com?
- Capture the results (by selecting all + copy) and send it backPlease mark the logs with the name of the carrier of the SIM card.
Thanks for your help in advance and hope we can help to resolve your issues.
benyba wrote:
Hi,
Benoit
I can provide the instructions to allow you downgrading to the previous release and see whether your device can work normally as you expect. After that, we can get some logs on the latest release to check what might be wrong.
Thanks
- jzz15Aspirant
In many eastern asia cities, like Hong Kong, Macau, Beijing, Shanghai etc.
The provider deployed SA base station and NSA network not available anymore, and MR5200 can not handle SA network, so this router can only connect to 4G+ network.
When MR5200 can enable 5G SA network?
SA support is planned for early next year. Please standby.
Thanks
- FEMANINJAAspirantWould sooo love to own this. It’s top of my list. Just bought 3 wifi routers. An Asus and 2 nighthawks. I’m keeping nh #3. :)
Previously I had your little lte modem and it’s a sweet lil device, the best of it’s kind- perhaps only. This m5 didn’t exist but now as I’m getting ready to cut the chord, I dream of owning this! Would love to test it out and review for you. And or anything else you’re curious for feedback… I’m a self employed (unemployed a’ la pandemic Covid reasons,) but have a 20yr bg with digital media and interactive tech. Researching securities and vpns and comparing for a myriad of uses. I’m just a singular being without official YouTube review channel nor are my various other presences on the web configured for monetization. Reviews and discussions I have are purely because I am a passionate and creative geek. If you have a program or policy for me to get into I would love to to review and promote and share, positives, I’m not into negativity, and there’s enough of that. I prefer to provide truth and dispel hearsay and false accusations that spread rather than help encourage great products in form and function and usability are known. Can’t afford this in this moment. If you have any thoughts please share. I’ve never actually written to a company in this way, exactly, so I’m finally just jumping in now.
As I see people reviewing and unboxing and sharing tips on set up and stuff on yt and all over the place and think to myself how much I’d love to do that. It’s something I just do anyway! I learn explore share compare… so how about I find a way to do that, too! Ok happy holidays - TUXonTheRoadAspirant
MR5200 = M5:
Setup1
SimCard NOS Portugal in M5 = some smartphones and tablets can connect to M5wifi, some cannot.
Setup2
Same SimCard in a tablet + M5 dataOffloading enabled = M5 redistributes the tabletWifi = now M5wifi.
The devices which could not connect in setup1 connect now successfully to M5wifi.
Why? Thank you for helpfull informations :-) chris
TUXonTheRoad wrote:
MR5200 = M5:
Setup1
Setup2
Thanks for reporteing the issue to us.
Could you please advise the WiFi client brands and medels? We can check on this.
Regards
Samsung Galaxy Tab S7+ 5G SM-T976B
wifi: WPA2-Personal, 2.4ghzNetgear MR5200 Nighthawk M5, H/W: 1.3, SN 6B2617WJ00E6A
wifi: WPA2 Personal AES, 2.4ghz
channel auto, standy disabled, range short, 2.4G: HT20, 5G: VHT80Clients with problems in setup1:
- iPhone11 MHDG3ZD/A iOS 15.1
- iPad 5.generation MP2H2TY/A iOS 14.8.1
- NoV1mTutorJust bought the M5 to replace my M1 now that 5G is available in my village .
Used it with 4G for a week now, cause I still didn’t upgrade to a 5G SiMcard and had no issue. To say I received the new SiM ! I was amazed, internet is so much faster!
But this evening, experienced two times a connection loss. The router still displayed that it received 5G network but my devices couldn’t connect to the internet. So I came here to get more informations on the subject and see that I’m probably not the only one in this case.- NoV1mTutorAnother precision, only way I found to solve it is to restart the router. So I restarted it two times today. It’s really since I switched to 5G that this issue appeared. During my week on 4G network, it was flawless.
NoV1m wrote:
Another precision, only way I found to solve it is to restart the router. So I restarted it two times today. It’s really since I switched to 5G that this issue appeared. During my week on 4G network, it was flawless.Thanks for the information. When you say your device can't access to 5G, could you please specify what devices are connected to M6 and by WiFi or by Ethernet cable?
Regards
John
Hi,
I am purchase MR 5200, I am using in IP Passthrough Mode.
If the device loses connection, I am unable to renew the DHCP lease.
Also I have noticed that during Boot Up, the device wants to assign a RFC1918 IP, but the local DHCP server is already disabled.
So it is not stable device to use as for LTE Failover.
Please contact me via Support Ticket for Details.
- BH_CNETGEAR Expert
Hi RonGonz, when your issue happened, was that only Ethernet connected devices could not go to the Internet? For WiFi clients connected to the M5 directly (not to another router which connected to the M5 through Ethernet), could they access the Internet?
RonGonz wrote:Hi,
- Chipster27Aspirant
Carrier: Verizon with Verizon 5G sim card
Hotspot: MR5200
Firmware Version: NTGX55_12.04.10.01
Firmware Build: 2021/08/30
Hardware Version: 1.1
PRI Version: 02.02
Problem: The device is losing data connection. I end up with a yellow warning triangle associated with the WiFi icon. When I click on it I get a message saying the device has lost data connection.
Any advice is appreciated.
Thanks
Sorry for replying late. The M5 NAS will not work with new Verizon SIM since new Verizon SIM requires on device activation. That is not supported by the device. But some Verizon customers did make the device work with their already-activated Verizon SIM card.
Thanks
- Chipster27AspirantGot it, thank you! I was able to activate the sim using my old device, then put the sim in my 5200 and it works.
- cyberfoxTutor
Hi,
I have a MR5200 and it connects and works great. However, I do want to monitor the router remotely. Check battery status, connected devices and data usage. I have tried all possible options accessing the router from external IP, but it simply will not work. Port forwarding, DMZ will not let me access the gateway IP from an external IP for web admin interface. I have changed the gateway IP. No luck. I have called the network operator, changed APN to a public APN (No firewalls). Still I am unable to even ping the router.
Can you help me access the MR5200 from outside the LAN?- JohnPengNETGEAR Expert
cyberfox wrote:
Hi,
Can you help me access the MR5200 from outside the LAN?This is not supprted by the carriers due to security risks. But some carriers do support the special plan for enterprise customers with VPN support, which will assign a fixed IP to M5 and allow the customer to access the network behind M5.
Netgear has its own remote management service that can be enabled on M5 as a subscription, which is called Insight Pro. You can check and see whether the service can meet your needs.
Thanks
- cyberfoxTutor
It is supported by the carrier. I do not need a fixed IP as DDNS takes care of the IP changes. I do have the public IP for the M5. According to the carrier the APN I am using is not behind any firewalls or CGNAT. The problem is the router not letting me under any settings access it from outside the LAN.
I have confirmed that I have a serial number prefix that are eligible for Insight. I have tried to enroll the serial number to the service, but the router shows up under 'My other devices' and I am unable to control it or manage it. It does not work.
- jslcomGuide
Hello all,
I've been using my MR5200 for several months and it's been pretty good. I recently tried using the data offloading feature, but it seems to have a quirk that affects my use case. I have successfully configured data offloading via Ethernet, but when the Ethernet connectivity goes away, the MR5200 does not switch back to mobile broadband. Just to be clear, the Ethernet PHY connection is still up, but the gateway is no longer reachable. If I physically unplug the Ethernet cable, the MR5200 will properly switch to mobile broadband, but apparently it will never switch unless the hardware PHY link is broken. I experimented with short DHCP lease times (such as two minutes) to see if the router would figure out that it no longer had a connection when the lease expired. Nope! It just keeps trying anyway.
Interestingly, when the Ethernet gateway stops responding, the MR5200 does send ICMP host unreachble messages back to the client, and even more interestingly, after the DHCP lease expires, the MR5200 begins sending ICMP net unreachable messages (instead of host unreachable messages). So the MR5200 obviously knows that it no longer has a gateway to offload to, but it doesn't care as long as the PHY is up. I would call this brain dead behavior on the part of the MR5200, and perhaps also on the part of the embedded developers who implemented the MR5200 data offloading feature.
Can I someday expect a product firmware update to address this issue?
Great Post! Wasn't aware of these issues myself, but thank you for pointing this out.
It's probably the underlying networking TCP/IP stack that is doing this.
Either the functionality has simply not been implemented (which is weird because you would think this device would go through some kind of QA testing suite to confirm proper basic operation before being released), or the existing functionality that was implemented is b0rk3n and QA testing missed it. Either way doesn't look very flattering on the Product Manager / Engineering team.
jslcom wrote:
Hello all,
Thanks for the detailed analysis! Definitely, it will help us to find the solution for this WAN port stability issue as reported in another thread on this topic.
- nasgulchAspirant
I got myself a 5200 because my M2's work flawlessly for 2 years.
I am having the following issue. Which does not exist with the M2's.
Using Swisscom as a provider here in CH with a public IP adress, My router is assigned the adress 178.x.x.x as shown in the first image below. Strangely enough the unit reports a private IP which comes from nowhere as shown in second image. The M5 is on latest FW 12_0412_00.
What is worse, when using IP Passthrough, the private adress is forwarded!!!
Swisscom provided public IP
Any input is appreciated
Erik
