gregmiller
Oct 14, 2020Aspirant
BR500 Mac VPN problem with Big Sur
My office has a br500 vpn router, and all the macs at home connect to it to do work. With big Sur, we are not able to connect any longer. The client software Netgear recomends - tunnelblick - no long...
keb
Nov 16, 2020Aspirant
I had the same issue after upgrade to Big Sur. Vpn to my nighthawk stopped working.
TAP mode is not supported anymore. (https://tunnelblick.net/cKextLoadError.html)
Solution using tunnelblick (or VIscosity):
Download "for non-windows" from Netgear advance seutp->VPN Service
Edit the. xxxx. conf file change the line starting with "remote" to "TUN" port (ip and port available in in Netgear advance seutp->VPN Service->tun mode service port)
Change "dev tap" to "dev tun"
Save
Add .tblk to the downloaded folder.
Drag to Tunnelblick (or import to Viscosity VPN)
Connect from Big Sur should now work.
More details here:
aer2345
Nov 21, 2020Aspirant
I tried what you said but am getting an error.
The OpenVPN log contains the following message:
"Unrecognized option or missing or extra parameter(s)".
This error means that an option that is contained in the OpenVPN configuration file or was "pushed" by the OpenVPN server:
• has been misspelled,
• has missing or extra arguments, or
• is not implemented by the version of OpenVPN which is being used for this configuration. It may be a new option that is not implemented in an old version of OpenVPN, or an old option that has been removed in a new version of OpenVPN. You can choose what version of OpenVPN to use with this configuration in the "Settings" tab of the "Configurations" panel of Tunnelblick's "VPN Details" window.
See the VPN log in the "Log" tab of the "Configurations" panel of Tunnelblick's "VPN Details" window for details.
- kebNov 21, 2020Aspirant
Hi
Sorry to hear that your config does not work.
Client side I am using Tunnelblick 3.8.5beta01 (build 5610) (or Viscosity which imports settings from Tunnelblick)
Here is my .conf (which works from Big Sur), maybe that could be helpful
Replace the "nnn.nnn.nnn.nnn" with router IP and "mmmm" with portnumber of the TUN
clientdev tunproto udpremote nnn.nnn.nnn.nnn mmmmresolv-retry infinitenobindpersist-keypersist-tunca ca.crtcert client.crtkey client.keycipher AES-128-CBCcomp-lzoverb 5
- Jan 04, 2019Retired_Member
