stef_dv
Mar 30, 2022Follower
BR500 PoE ?
I was wondering if the BR500 router had the PoE (Power over Ethernet) protocol on all its Rj45 ports? Just because I would like to add a WAX610 without an external power supply… Thanks
Mar 30, 2022Guru - Experienced User
I was looking through its datasheet and manual and didn't see that it has POE capabilities. Did you find something that suggested otherwise?
schumaku
Impossible. One WAX610 does need 802.1at (PoE+), from the specs supplying one with power would require more tag 30W just to provide the standard specific 30 W at the PD (powered device), so we can't even think about up to four PoE+ ports. The BR500 (also rethink the price!) is powered by a 12V/1.5A power supply only.
