stef_dv
Mar 30, 2022Follower
BR500 PoE ?
I was wondering if the BR500 router had the PoE (Power over Ethernet) protocol on all its Rj45 ports? Just because I would like to add a WAX610 without an external power supply… Thanks
Geoff-NZ
May 03, 2022Apprentice
In short, no the BR500 does not have PoE network ports.
If you were only wanting a minimum number of PoE access points, like the WAX610, then you should be able to use a Gigabit PoE+ injector. However, if you want multiple, you will probably be better of with a PoE switch (I got the MS510TXPP for similar setup and it works a treat).
