Kennymcchau
Jan 27, 2021Tutor
BR500 port forwarding for specific ip
Hi Experts, We have a BR500 router and a linux server at the back end. The vendor support need to access this linux server with port 22. But this server is also a web server that will allow port 80...
schumaku
Jan 28, 2021Guru - Experienced User
In my understanding, you can setup port forwarding and firewall rules eg. for 22/TCP in the local GUI of the BR500 interface. However, Insight does not support the ability to setup the rules in Insight yet.
- KennymcchauJan 28, 2021Tutor
schumaku wrote:In my understanding, you can setup port forwarding and firewall rules eg. for 22/TCP in the local GUI of the BR500 interface. However, Insight does not support the ability to setup the rules in Insight yet.
Thanks Schumaku,
I know I can setup the port forwarding for port 22 to the linux server, but after I set this rule, the router log will show a lot of DoS Scan attack to this server from other IP. So I hope I can only allow a particular IP to access this server and deny all other access for port 22 .
Is it possible?
Thanks.
- schumakuFeb 08, 2021Guru - Experienced User
As mentioned, Insight might not support this, however you can use the local device UI to configure firewall rules.
- KennymcchauFeb 08, 2021Tutor
schumaku wrote:As mentioned, Insight might not support this, however you can use the local device UI to configure firewall rules.
Thanks Schumaku,
May I know how to access the local device UI? Somthing like telnet or Putty?
