Kennymcchau
Jan 28, 2021Tutor
BR500 port forwarding for specific ip
Hi Experts, We have a BR500 router and a linux server at the back end. The vendor support need to access this linux server with port 22. But this server is also a web server that will allow port 80...
Kennymcchau
Feb 09, 2021Tutor
schumaku wrote:As mentioned, Insight might not support this, however you can use the local device UI to configure firewall rules.
Thanks Schumaku,
May I know how to access the local device UI? Somthing like telnet or Putty?
schumaku
Feb 09, 2021Guru - Experienced User
Using a Web browser of course.
- KennymcchauFeb 09, 2021Tutor
schumaku wrote:Using a Web browser of course.
Thanks, but I have setup the port forwarding of port 22 and will open for all connections. Seems there is no solution for this model.
- schumakuFeb 09, 2021Guru - Experienced User
Of course there is ... each BR500 (and BR200) can be managed locally to some extent from a Web browser. Consult the fine BR500 documentation please, chapter "Manage custom firewall traffic rules". The same documentation certinly also shows on how to access the router Web user interface ...
An existing port forwarding for 22/TCP does not prohibit anything.
- KennymcchauFeb 10, 2021Tutor
I have tried to use the traffic rules but the port column is dimmed that I cannot type the port range or only port 22.
