Ppummill
Jul 14, 2019Apprentice
BR500 Reboot deletes configuration settings
What am I doing wrong? When the BR500 reboots, I loose Port Forwarding rules, DHCP Address reservations, OpenVPN, Dynamic DNS. I've tried saving settings as a backup and then restoring the backup...
- Jul 31, 2019
The BR500 has been replaced with the new one that Netgear sent.
This particular issue has been fixed.
thank you
DaneA
Jul 15, 2019NETGEAR Employee Retired
Found out that you have already contacted NETGEAR Support with regard to your concern. Your support ticket has been escalated already to the Level 3 tier. You may post here any updates on your support ticket.
DaneA
NETGEAR Community Team
- PpummillJul 15, 2019Apprentice
Thank you for your response,
I will certainly post with updates and hopefully the solution when this is resolved.
- PpummillJul 22, 2019Apprentice
After a two hour chat session, I was referred to a higher level of support. They believe that the problem is being casued by bad flash ram. An RMA has been issued. When the new unit is in position, I'll report back.
I wonder if this would have continued to be an issue if the settings I was changing could have been accessed from within the Insight app. There is a lot that is only accessible via the web UI on a locally connected computer.
- PpummillJul 31, 2019Apprentice
thank you
