dfilip
May 31, 2019Guide
BR500 Rebooting Itself
I've noticed that my BR500 occasionally reboots itself. Has anyone else noticed this? It started doing this after I did the following (not sure which, if any, contributed): upgraded firmware to ...
- Jun 29, 2019
[Sorry to cross-post, but I made the error of splitting and overlaping my problems across two different threads here, and I want to accept this as my solution to both].
Just an FYI to anyone else who experiences any of this: I have disconnected my BR500 from the Insight service, rebooted the router, and the VPN messages have stopped (obviously!), the "NAT loopback" is allowing my LAN to reliably take advantage of port forwarding (sub-second connection again, before was either hanging or taking 10+ seconds to connect), and my router has stopped randomly rebooting itself. Also, I am no longer seeing the sporadic high-CPU (sporadically 30 - 60+ percent) on the BR500.
Of course I no longer have any VPN (as ports 12973 (TUN) and 12974 (TAP) hang, even when the Open VPN service is enabled, which is the only reason why I enabled Insight + Instant VPN). But having a stable, reliable, working router is much more important to me.
Another user on this forum shared that Netgear had suggested disconnecting from Insight as a possible solution to the random reboots, which is why I am sharing this, in the hope that it may help others.
No promises, your milage may vary, void where prohibited by law, etc., but for anyone who is at their wits end and frustrated with the BR500, as I was, this maybe a possible solution to regain stability if you can live without the Insight service.
dfilip
Jun 24, 2019Guide
It was any hosts ... and ports ... but only when connecting from the LAN to the BR500 external IP, whereas from the WAN to the BR500 external IP worked fine.
But I think now all is good again ... everything seems to be working again with "NAT loopback", such that I can reliably connect to all of the ports and all of the hosts that I have port forwarding on.
I removed the BR500 from my Insight account, the once-per-minute VPN messages have stopped, the LAN port forwarding seems to be working again, and so far no random reboots or high CPU usage ... fingers crossed! ;-)
dfilip
Jun 29, 2019Guide
