Ppummill's avatar
Ppummill
Apprentice
Jul 14, 2019
BR500 Reboot deletes configuration settings
What am I doing wrong?
When the BR500 reboots, I loose Port Forwarding rules, DHCP Address reservations, OpenVPN, Dynamic DNS.
I've tried saving settings as a backup and then restoring the backup, but the reboot part of that process just resets everything.
When I re-create the DHCP Addresss reservations, they don't take effect until a reboot.  Which clears out the settings.
Am I missing a "Save Settings" button somewhere in the UI?
I have to have OpenVPN operational for the many times that Insight Instant VPN fails.
anyway, I'm kind of at a loss for what to do next.  Other than setting aside three to four hours to call phone support...
thanks
-patrick
  • The BR500 has been replaced with the new one that Netgear sent.
    This particular issue has been fixed.
    thank you
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Ppummill,
    Found out that you have already contacted NETGEAR Support with regard to your concern.  Your support ticket has been escalated already to the Level 3 tier.  You may post here any updates on your support ticket.
    DaneA
    NETGEAR Community Team
    • Ppummill's avatar
      Ppummill
      Apprentice
      Thank you for your response,
      I will certainly post with updates and hopefully the solution when this is resolved.
      • Ppummill's avatar
        Ppummill
        Apprentice
        After a two hour chat session, I was referred to a higher level of support.  They believe that the problem is being casued by bad flash ram.  An RMA has been issued.  When the new unit is in position, I'll report back.
        I wonder if this would have continued to be an issue if the settings I was changing could have been accessed from within the Insight app.  There is a lot that is only accessible via the web UI on a locally connected computer.
ProSupport for Business
