rjwerth28
May 17, 2020Guide
BR500 Traffic Count completely wrong
For some time now, one of my BR500s traffic count is completely wrong. For example, as of right now, it thinks it has moved 2943.79TB of data in the last 24 hours. I don't need to tell you that it ...
rjwerth28
May 28, 2020Guide
Software is 5.8.01. I have performed several resets but the last one might have worked.
The network couldn't be simpler with a cable modem, the Br500 router with a client on one port and an 8 port unmanaged switch on the other port which takes care of all the other hardwired items in the office.
rjwerth28
Jul 23, 2020Guide
Well, this router is at it again. 17.78TB in 24 hours is being reported. Is there any fix to this???
- DaneAJul 29, 2020NETGEAR Employee Retired
We apologize for the inconvenience this has caused you. Found out that you already have an ongoing support ticket with NETGEAR Support. You may want to post here the progress of it.
DaneA
NETGEAR Community Team
- rjwerth28Aug 19, 2020Guide
4 days dealing with Tier 3 support and the best they have is "have you tried resetting the router?" Geez.
- reyiiJan 20, 2021Aspirant
Hi,
I'm having similar problem with my Router BR500.
Firmware 5.10.0.3
Insight Managed
It has been reseted.
1 week frame traffic count is messed up, flat, no data.
24 hours frame is OK
8 hours frame is OK.
