Retired_Member's avatar
Retired_Member
Jan 18, 2019
BR500 vpn insight
Does the vpn insight work well if the br500 is behind another router?
I did the vpn but it is a bit 'too slow .. Usually what values ​​of latency must we have?
Thank you so much for any answers
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Marce88,
    Welcome to our community! :)
    It seems that you wanted the VPN Insight to work while it is behind another router. There is no particular latency that the engineering team has provided. Have you ever tried swapping it with the other router and check if it will provide the same information?
    • Retired_Member's avatar
      Retired_Member
      Hi John I will try to do this test. thank you so much
ProSupport for Business
