kc6108
Jan 04, 2022Luminary
Business SOHO Router Options
I have five SRX5308 routers that I need to replace and another deployment needing a router. I have a spare SRX5308 that I could use in the meantime, but they have been EOL for so long now. I had pu...
kc6108
Deploying Cisco Small Business RV routers alongside Netgear switches, WAPs, etc are no longer an option. The entire line of RV routers are now EOL.
https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/small-business-rv340-rv345-series-eol.html
I have deployed a lot of those routers/vpn firewalls in my day.
Now would be a good time for Netgear to work on a robust vpn firewall solution like the SRX5308 was just a few years ago.
- schumakuJan 04, 2022Guru - Experienced User
kc6108 wrote:
Now would be a good time for Netgear to work on a robust vpn firewall solution like the SRX5308 was just a few years ago.Indeed. In absence of anything reasonable, you might have an eye over there for example.
Orbi Pro 6 are nice for simple throw-in solutions - with growing complexity I have my concerns, and stick with typically wired WAC5xx and WAX6xx, all Insight managed, simple and robust.
