ajbaum
Oct 31, 2015Aspirant
Can't delete LAN routing table
When I log into my FVG-318, in Network Configuration->LAN Setup->LAN Groups, "Known PC and Devices" table has a lot of entries, most of which are no longer connected (most of which are wireless conne...
DaneA
Nov 01, 2015NETGEAR Employee Retired
Hi ajbaum,
Let us isolate the problem. Kindly answer the questions below:
a. Have you used other browsers like Firefox or Safari?
b. Have you tried to clear the browser cache then try to delete or reset the entries in the "Known PC and Devices" table?
c. What is the current firmware version of the FVG318?
d. Have you tried to reboot the FVG318 after trying to delete or reset the entries in the "Known PC and Devices" table?
e. DId you perform a factory reset on the FVG318?
I look forward to your response. Welcome to the community! :smileyhappy:
DaneA
NETGEAR Community Team
- ajbaumNov 10, 2015Aspirant
yes
yes
v2.1.2-43N
yes
no - I've been trying to avoid that. I am unclear what I lose if I do that.
