Megunticook
Feb 08, 2018Aspirant
can't update firmware on FVS318Gv2
Been having some connectivity issues with my FVS318Gv2 so started troubleshooting by first upgrading firmware. I'm at version 4.3.3-8 and I downloaded version 4.3.5-3, tried installing through my adm...
- Mar 08, 2018
NG finally sent an identical replacement unit (overnighted free of charge--much appreciated).
I connected my laptop to it, fire up a browser, and it updated the firmware to the latest version without a hiccup.
Have it in service now and so far so good.
Thanks.
DaneA
Feb 14, 2018NETGEAR Employee Retired
I just want to follow-up on this. Were you able to perform the steps I suggested? If yes, what is the result?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Megunticook
Feb 14, 2018Aspirant
Thanks for your follow-up. Just waiting for a good opportunity to do this, can't afford the downtime right now.
Also, if I try the upgrade and end up bricking my router, that would be very bad because it would effectively shut down my business.
Worst case scenario, if that happened, would Netgear overnight a new router to me under warranty? Mine is less than 2 years old.
