PasavICT
Jul 12, 2016Aspirant
Change IP address VPN Tunnel between 2 SRX5308
We moved our network so i need to change my IP address of one of the SRX5308 VPN tunnels. But i can't edit the IP address of the other side ? Do i need to make a new tunnel or can i change it somehow...
- Jul 12, 2016
Hi PasavICT,
Welcome to the community! :)
You might need to close the tunnel as well as disable the VPN/IKE Policy before you make any changes.
DaneA
NETGEAR Community Team
PasavICT
Jul 18, 2016Aspirant
Thxs for the fast response, i forgopt to disable the ipsec tunnel, after that i could easy change my ip.
So it is solved !
DaneA
Jul 18, 2016NETGEAR Employee Retired
Hi PasavICT,
You're welcome! I am glad to know that its now solved. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
