robert5150's avatar
robert5150
Classical Routing - Assistance needed
I am trying to get routing mode (Note: not NAT mode) working through my Netgear Firewall. It's an FVS336G v2. I have the following CIDR Block and IP Address from my ISP - COX.
My block is as follows:
Customer: (My range of static IPs)
68.xxx.xxx.65 < Gateway
255.255.255.224 < Mask
Usable: 68.xxx.xxx.66-92
WAN: (IP and Gateway provided by COx for their Endpoint)
57.224.xxx.100 : WAN IP
255.255.255.240 : Mask
57.224.xxx.97: Gateway
If i setup my Netgear with the above IP info and then set my laptop to use 1 of the IPs in my Range (Customer) - I am not able to ping anything or browse any websites - Using classical routing as the WAN mode.
However if i change nothing else on my laptop and set the netgear to use NAT Mode it works fine. The problem is my ISP's (WAN IP) is showing and not one of my static IPs.
I have several servers that need to have static IPs and cannot use NAT. I bought this firewall beucase it says it supports classical routing.
When in classical routing mode if i use the diagnostics page and ping 4.2.2.1 (from within the firewall) it works as expected yet i cannot ping 4.2.2.1 using my laptop - unless i am set the netgear to NAT mode.
any ideas?
Thanks
  • Thanks for your help! The issue is now resolved. The problem was it took COX forever to get my line routing correctly.
    I did not make add any routes to my firewall and have it running in classical routing mode as I originally wanted to do.
  • You're welcome - took me a bit of thinking - the last time I encountered this situation would have been nearly fifteen years ago, when I first started building private WANs - it had me stumped for days.
ProSupport for Business
