argylegp
Apr 22, 2015Novice
Clock skew detected
What does "Clock skew detected" mean?
It's showing up in the router log.
- RXLuminaryIt seems that your concern is similar to this forum link: http://forum1.netgear.com/showthread.php?t=38813
- argylegpNoviceHow come it shows up in the logs on one of the routers and not the other?
They are both the same and have the latest firm-ware.
Has this error ever been fixed?
Does it cause the router to reboot? - NhellieVirtuosotry using these NTPs
us.pool.ntp.org , 0.pool.ntp.org , 1.pool.ntp.org , 2.pool.ntp.org ,3.pool.ntp.org - argylegpNoviceI tried those.
I currently have it set to time.nrc.ca
Can I set it to the IP address of the time server in my Windows Server 2008 r2 ? - NhellieVirtuosoYes, I believe you can.
- AmarendraksAspirant
Hi Guys,
i am very new to the community and using FVS336Gv3 and looking forward for your help.
i changed below settings in Time Zone and post changes i am getting getting Clock skew detected alerts in logs.
These changes made because i am getting Jun 2015 when looking for logs
# Changed GMT to -08:00 Pacific time (US) from + 05:30 Bombay, calcutta
# enabled Automatically adjust for dayligt savings
# changed NTP server to default.
Also please check is thier any issue with it.
