madmacs
Apr 02, 2020Aspirant
Configuring a Guest Wifi Network with BR500 and WAC510
Configuring a Guest Wifi Network with BR500 and WAC510 I am configuring a BR500 router and a WAC510 for a resterant. I would like to configure the network so we can use one of the SSIDs for...
MrJoshW
Apr 02, 2020NETGEAR Employee Retired
Hello,
You would need to create a VLAN for the guest network and to assign an SSID to the guest VLAN. If you are using Insight you can board both devices and use the VLAN configuration wizard to setup the VLAN and assign the ports to be part of the VLAN. During the wizard setup it will ask you to create an SSID as well as assign an IP subnet to the VLAN.
More information on how to setup a VLAN in Insight can be found here:
https://kb.netgear.com/000044352/How-do-I-set-up-a-custom-VLAN-in-Insight
