wispman
Jan 31, 2022Aspirant
Connecting two FVS318v2 VPN Servers each running under a gateway routers - VPN tunnel between them
I am trying to create a VPN connection between two FVS318v2 routers both running firmware V2.4 (July. 19 2004). Each FVS318 router is connected under the main gateway router that connects to the Int...
wispman
Feb 07, 2022Aspirant
I am informed that my router behind router VPN will not work. I have read elsewhere the port forwarding IPsec port 500 and L2TP port 1701 to the VPN routers may allow it to work. Yes, No?
