smansfield
Jun 13, 2013Aspirant
Constant SRX5308 Issues
First of all, we seem to have a unit with a dodgy WAN 1 port; if you connect anything and touch the cable (the lightest touch) it breaks the connection. So effectively we have a 3-port load-balancer, ...
georgesh
Hello.
You may try to downgrade the firmware - I use 3.0.8-12 with my SRX5308.
None of the 4.x worked properly with my device.
Do not forget to document your network settings, since you cannot restore them going from firmware 4 to 3.
