hhertz
Apr 28, 2016Aspirant
Content Filtering Trusted Domains
If I add domains to the trusted list, does the firewall know to not trust all the rest that are not in the trusted list? Would that be the default behavior? My hope is that if I add a trusted domai...
JohnRo
Apr 29, 2016NETGEAR Employee Retired
Hello hhertz,
Welcome to the community!
Trusted domains are domain names that when they are added they will be bypassed by the Keyword filtering. An example given on one of our Help tools on the UI of our routers: If yahoo is added to the Blocked Keywords list and www.yahoo.com is added to the Trusted Domain list, then www.yahoo.com will be allowed but mail.yahoo.com will not be allowed. So, to answer your question it will depend on what you have defined on the blocked keyword list and the trusted domain list.
Let us know if you have more questions.
Thanks,
nextinfra
Sep 06, 2016Tutor
Hi,
In the FV338.. the limit is 64 keyword (trusted domain) and it's short, is it the same in the fvs336 ?
Thanks
- JohnRoSep 06, 2016NETGEAR Employee Retired
Hello nextinfra,
Yes, it is the same for all of the models. Up to 64 keywords can be added to the list. If there is a need to add more keywords and if a lot of users think it is necessary, you can forward it as a feature request/improvement.
Thanks,
- nextinfraSep 07, 2016Tutor
Thanks for your answer, but where can i do this "a feature request/improvement" you know the entry point ?
Best regards
- JohnRoSep 07, 2016NETGEAR Employee Retired
Hi nextinfra,,
You can post this request on our Idea Exchange Board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.Also, you can open a Support Request for feature improvement.
Hope this helps.
Thanks,
