hhertz
Apr 28, 2016Aspirant
Content Filtering Trusted Domains
If I add domains to the trusted list, does the firewall know to not trust all the rest that are not in the trusted list? Would that be the default behavior? My hope is that if I add a trusted domai...
nextinfra
Sep 06, 2016Tutor
Hi,
In the FV338.. the limit is 64 keyword (trusted domain) and it's short, is it the same in the fvs336 ?
Thanks
JohnRo
Sep 06, 2016NETGEAR Employee Retired
Hello nextinfra,
Yes, it is the same for all of the models. Up to 64 keywords can be added to the list. If there is a need to add more keywords and if a lot of users think it is necessary, you can forward it as a feature request/improvement.
Thanks,
- nextinfraSep 07, 2016Tutor
Thanks for your answer, but where can i do this "a feature request/improvement" you know the entry point ?
Best regards
- JohnRoSep 07, 2016NETGEAR Employee Retired
Hi nextinfra,,
You can post this request on our Idea Exchange Board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.Also, you can open a Support Request for feature improvement.
Hope this helps.
Thanks,
- JohnRoSep 12, 2016NETGEAR Employee Retired
Hi nextinfra,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
