Gareth629
Nov 19, 2020Aspirant
Copy of config from Br500 to BR200
Hi, I have purchased a BR200 to replace a BR500. Is it possible to copy the config from the 500 to the 200? Thanks Gareth
- Nov 27, 2020
Hi Gareth629,
Welcome to our community! :)
Yes, you may use the configuration file of the BR500 to BR200. The only thing that will not show up on the BR200 is your configuration from the VPN. Other configurations should work fine.
John
NETGEAR Community Team
JohnC_V
Nov 27, 2020NETGEAR Employee Retired
Hi Gareth629,
John
Gareth629
Dec 09, 2020Aspirant
Thank you
