techvslife
Dec 02, 2011Novice
Custom ports blocked: Port range conflicts with default service
I have a new dual wan FVS336GV2 router, and installed the latest firmware. But I find it I can't configure it the same as my old dual wan router. I run into two problems: 1. When I create a "cu...
adit
Dec 03, 2011Mentor
No and No.
I have recently requested that the list the predefined rules to include the port number and protocol. i.e. HTTP-80-TCP, DNS-53-UDP. I suggest you do the same with Tech Support.
You cannot create a custom Service that conflicts with a built-in Service. i.e port 500 UDP (used for IPSec VPN), port 80 HTTP TCP, etc.
You have to define rules for each WAN.
