BPDriscoll60's avatar
BPDriscoll60
Disneyplus.com blocked
Recently, I have not been able to access Disneyplus.com on any device connected to my Orbi network, either WiFI or hard-wired. However, I can use my phone's Wireless connection to access Disneyplus.com, and I can access it through my Backup Internet, T-Mobile Home Internet. I've looked at the logs on my Orbi and don't see any blocking there, and I don't have anything blocked. I do run Netgear Armor. I have disabled it and tried but got the same results: Disneyplus.com is blocked. Occasionally, when I try to access the website, I will get an error 73, which states that I may be in an area where Disneyplus.com is not accessible, but I have checked, and I have access. No VPNs are running either. So, I am still trying to troubleshoot the issue. Ideas would be helpful. It is only Disneyplus.com that is not accessible. All other streaming works. Thank you for your assistance
  • FURRYe38's avatar
    After disabling Armor, did you power off the RBR for 1 minute then back on then try that site?
    Has this site worked thru the Orbi system at all or is this the first time you have encountered this?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    • BPDriscoll60's avatar
      BPDriscoll60
      Thank you for your response.
      I did not power down the router after disabling Armor. I will try it again and see if it makes a difference.
      DisneyPlus.com has always worked, and this is a recent development. I plan to contact Comcast/Xfinity to see if they can offer a solution. I believe that something they did recently caused the issue. As I stated in my last message, only DisneyPlus.com is being affected.
      Current Firmware is on the Orbi is: V7.2.6.31_5.0.24
      The modem is a NG CM2000 with Firmware version V8.01.02 and Hardware version of 1.01
      It is all connected to Xfinity 1.2Gb internet.
      I'm sure I have a short CAT6 cable connected between the two.
      Let me know if there is anything else you need or you can advise to assist with resolution.
      Thank you again
      • FURRYe38's avatar
        Was it working after v.31 FW was applied to the Orbi system?
