aamer
May 10, 2017Follower
does SRX5308 support vrrp
does SRX5308 support VRRP and stateful high availabilty with active/active dual box clustering
- May 11, 2017
Hi aamer,
Welcome to the community! :)
I'm afraid to inform you that the SRX5308 does not support VRRP as well as stateful high availabilty with active/active dual box clustering. Kindly refer to the specifications of the SRX5308 indicated on the data sheet here.
As far as as I know, VRRP (Virtual Router Redundancy Protocol) is supported on manageable switches such as the NETGEAR M5300 series and M4300 series switches. Kindly check the article below:
What is the Virtual Router Redundancy Protocol (VRRP) and how does it work on my managed switch?
For more information about the NETGEAR M5300 and M4300 series switches, kindly access the links below:
DaneA
NETGEAR Community Team
DaneA
May 11, 2017NETGEAR Employee Retired
Hi aamer,
DaneA
