rogerp
Oct 06, 2018Aspirant
Enabling Weighted Load Balancing Dual WAN, incoming forwarding breaks
We have a working SRX5308 with a single WAN (WAN1) and incoming port forwarding working for several services (HTTP, SMTP, etc.)
When I connect a second WAN (WAN2), and then enable Weighted Load...
DaneA
Oct 07, 2018NETGEAR Employee Retired
Hi rogerp,
Since you have configured Load Balancing, I suggest you to configure Protocol Binding as well. Kindly read pages 41 - 44 of the SRX5308 reference manual here about Load Balancing Mode and Protocol Binding.
DaneA
NETGEAR Community Team
rogerp
Oct 07, 2018Aspirant
Protocol Binding is used to bind *outgoing* traffic to a particular WAN interface. My problem has to do with incoming traffic.
Unless what you're suggesting is that (eg. HTTP) traffic coming in on WAN1, is port forwarded to a particular server, and a protocol bind is necessary to guarantee that server's responding outgoing HTTP traffic heads back out through the same WAN. But shouldn't traffic normally always return on the WAN interface it comes in on?
- DaneAOct 11, 2018NETGEAR Employee Retired
Kindly double check the inbound firewall rule/s configured in order to ensure that the incoming service is still sent to the correct LAN server. If ever the inbound rule/s is still set correctly, then configure protocol binding as a test to see if it works.
DaneA
