rmustard
Sep 11, 2012Aspirant
eprint issue thru FVS318v3
Using printer's embedded web services 'enable' function, eprint capability for HP Laserjet Pro 400 M401n with unable to get thru FVS318v3 router (BTW: VPN not turned on). Per HP's instructions, have a...
adit
Sep 11, 2012Mentor
My bad, didn't think that old router had it.
What is the Remote Management port of the router?
Did you configure the Services with TCP, UDP or TCP/UDP?
Default gateway setup on the printer?
Read my LAN Subnets NOT to Use tutorial as well (nothing to do with your issue).
