rmustard
Sep 11, 2012Aspirant
eprint issue thru FVS318v3
Using printer's embedded web services 'enable' function, eprint capability for HP Laserjet Pro 400 M401n with unable to get thru FVS318v3 router (BTW: VPN not turned on). Per HP's instructions, have a...
rmustard
Sep 12, 2012Aspirant
Remote Management: not enabled - ever
Services configured with TCP/UDP -- and port forwarding for the printer are set up as the priority order rules (i.e. #1, #2... positions)
Default gateway setup on the printer points directly to router (192.168.0.1)
BTW: as briefly noted above, this is a home install. At the time of purchase I urgently needed to replace my prior Linksys unit and this was the only 8-port item 'on the shelf' at BestBuy. Wasn't looking for anything fancy, having VPN (never turned on), etc. Just needed a replacement that evening..... ugh....
Thanks mate.
Thanks mate.
