tdehan
May 04, 2019Aspirant
Every morning my FVS318Gv2 disconnects from my modem
Every morning my FVS318Gv2 disconnects from my modem. In order to fix the issue I have to login into the switch (http://192.168.1.1). Within a few seconds of logging into the switch my internet con...
additude
May 04, 2019Virtuoso
So,
Are you saying that the output of the Modem goes to the managed switch and that the device that you are using to "Log Into" the switch with is connected to the switch and that you have other devices attached to the switch as well?
Is the "Modem" also acting as a router? or is it acting as a bridge?
More precise information please.
- tdehanMay 04, 2019Aspirant
The cable is connected to the Motorola Cable Modem (MG7540). The MG7540 has 4 network port. I am connecting from one of the network port to the FVS318Gv2. All other computers and one Xbox in the house are wired connected to the FVS318Gv2.
- additudeMay 06, 2019Virtuoso
OK,
The Networtk needs to be setup so that the modem is also your router and the modem/router output needs to feed the FVS318Gv2 that feeds all of your other cabled equipment, which is what it wounds like you have.
The FVS318Gv2 is also in itself a Firewall capable of NAT. So diable the NAT in the FVS318Gv2 and use "Classical Routing Mode" because you may have what is called "Double NAT" going on here...
To reset the FVS318Gv2 you will need to push the reset button in and hold it for a slow count to 10... like 20 seconds....
Try those things.
- tdehanMay 06, 2019Aspirant
The issue has been fixed. It merely needed to have the FVS318Gv2 reset to Factory Settings. That alone solved the issue.
