Goretech's avatar
Apr 12, 2018
XR500 disconnected every morning
I just got the XR500 6 days ago and so far each morning I goto my wired desktop and its disconnected. I can't access the UI of the router or the internet.  A quick power button off/on, then some waiting fixes this issue but its very annoying.
Firmware Version V2.2.1.10
Any help would be greatly appreciated.  I am on the verge of taking it back to Best Buy.
  • Goretech's avatar
    Goretech
    Apr 22, 2018
    Currently, I believe setting QoS to always has stopped it from causing disconnects.  I have another issue but will post in a new thread.
  • Does this occur for all devices or is it only for your desktop? Is there anything specific happening on the network during the night? If you do a factory reset and then monitor it does it happen again?
    • Goretech's avatar
      Goretech
      Guide
      I just did a factory reset. I will monitor overnight and let you know. I will test all devices before rebooting if it happens again.
      Thanks,
      -G
      • JasonN's avatar
        JasonN
        NETGEAR Employee Retired
        Hi Gioretech,
        Thank you for the response!
        Please keep us updated. :]
        - Jason N
