prakashch
Mar 07, 2017Aspirant
Firewall FVS318Gv2 not responding connection to WAN from Verizon FIOS router MI424WR-GEN3I
Hi, I am unable to connect the Firewall to the verizon router. The WAN port does not show the LED lit up, nor does the verizon router detect the Firewall device. If I connect the Firewall WAN to...
- Mar 08, 2017
Hi DaneA,
Thank you for the explaination.
This is what I had tried after I had replied last.
1. I tried the Factory reset & tried to connect to Verison MI424WR-GEN3I. This would not til up.
2. I again retried Factory reset & connected to the Linksys. I could see one Green & one Amber. The Linksys did not show the new device, nor did the Firewall FVS318Gv2 show any WAN IP.
3. Even without restart I connected the WAN to WNDR 3800. I could immediately see 2-Green LED. The Firewall showed up WAN IP.
I do not understand what is the difference here between these 3 routers.
Thank you,
Prakash
SamirD
Mar 09, 2017Prodigy
The Verizon FIOS router is a bit of a funny device. What exactly are you trying to do? Because it may need more configuration on the FIOS gateway to work.
prakashch
Mar 10, 2017Aspirant
Hi SamirD
Earlear this Firewall was configured on my netgear WNDR3800. The WNDR3800 was connected to FIOS. Evey thing was working fine. However to connect to device under the firewall I had to make a VPN connection while connected to WNDR3800. To avoid all this I thought of moving the Firewall to one level up so that I wound not have to connect via VPN while connected to WNDR3800. Also, that way I would be able VPN from outside world.
As you just said, I did find some blogs that described the issues with configuring FVS318Gv2 with FIOS. I then deviced to get something to bridge the FIOS & the FVS318Gv2. So, I got the linksys. I was then trying to configure as follows
FIOS > Linksys > FVS318Gv2 > WNDR3800.
As I described in my previous posts, I was unsucessful in configuring the FVS318Gv2 even with the linksys. Thus, making me wonder if there is some special connection requirement for the firewall.
Thanks
- SamirDMar 10, 2017Prodigy
It has been a few years since I dealt with the FIOS gateway, but I think I actually ended up setting the fvs in the dmz to get it to work properly. As far as the wan light, that is a bit of an oddity, but I would check the settings in both the FIOS and fvs and set them manually to the same speed/duplex if need be. Sometimes autonegotiation still doesn't work.
- prakashchMar 15, 2017Aspirant
Thank you all for helping me to find solution.
Just so that this may help some one to resolve their issue-
While the exact reason that resolved the problem could not be tracked, the following steps appear to have resolved the problem
1. The LED on the Firewas would not light up because one of the reasons was the cable. Some how the same cable worked for the WNDR3800, but it did not for the firewall.
2. While working on an attempt to configure, something went wrong in the FIOS. MI424WR-GEN3I. I called up Verison & ended up resetting the router/modem.
3. Finding a post about the FVG318Gv2, I upgraded the Filmware. The post described a bug fix in the new version.
Thank you once again.
