prakashch
Mar 06, 2017Aspirant
Firewall FVS318Gv2 not responding connection to WAN from Verizon FIOS router MI424WR-GEN3I
Hi, I am unable to connect the Firewall to the verizon router. The WAN port does not show the LED lit up, nor does the verizon router detect the Firewall device. If I connect the Firewall WAN to...
- Mar 08, 2017
Hi DaneA,
Thank you for the explaination.
This is what I had tried after I had replied last.
1. I tried the Factory reset & tried to connect to Verison MI424WR-GEN3I. This would not til up.
2. I again retried Factory reset & connected to the Linksys. I could see one Green & one Amber. The Linksys did not show the new device, nor did the Firewall FVS318Gv2 show any WAN IP.
3. Even without restart I connected the WAN to WNDR 3800. I could immediately see 2-Green LED. The Firewall showed up WAN IP.
I do not understand what is the difference here between these 3 routers.
Thank you,
Prakash
prakashch
Mar 14, 2017Aspirant
Thank you all for helping me to find solution.
Just so that this may help some one to resolve their issue-
While the exact reason that resolved the problem could not be tracked, the following steps appear to have resolved the problem
1. The LED on the Firewas would not light up because one of the reasons was the cable. Some how the same cable worked for the WNDR3800, but it did not for the firewall.
2. While working on an attempt to configure, something went wrong in the FIOS. MI424WR-GEN3I. I called up Verison & ended up resetting the router/modem.
3. Finding a post about the FVG318Gv2, I upgraded the Filmware. The post described a bug fix in the new version.
Thank you once again.
