prakashch's avatar
prakashch
Firewall FVS318Gv2 not responding connection to WAN from Verizon FIOS router MI424WR-GEN3I
Hi,   I am unable to connect the Firewall to the verizon router. The WAN port does not show the LED lit up, nor does the verizon router detect the Firewall device. If I connect the Firewall WAN to...
  • prakashch's avatar
    prakashch
    Mar 08, 2017
    Hi DaneA,
    Thank you for the explaination.
    This is what I had tried after I had replied last.
    1. I tried the Factory reset & tried to connect to Verison MI424WR-GEN3I. This would not til up.
    2. I again retried Factory reset & connected to the Linksys. I could see one Green & one Amber. The Linksys did not show the new device, nor did the Firewall FVS318Gv2 show any WAN IP.
    3. Even without restart I connected the WAN to WNDR 3800. I could immediately see 2-Green LED. The Firewall showed up WAN IP.
    I do not understand what is the difference here between these 3 routers.
    Thank you,
    Prakash
ProSupport for Business
