lumandryk's avatar
lumandryk
Firmware FVS318N_v4.3.5-3.img invalid or corrupted
Trying to update my router to this firmware (FVS318N_v4.3.5-3.img) and both the web gui and the telnet interface keep complaining that the file is invalid or corrupted. Does anyone know how to solve this problem?
Thanks!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi lumandryk,
    Welcome to the community! :)
    As far as I know, there are no issues about upgrading the firmware of the FVS318N to v4.3.5-3.  Kindly answer the questions below:
    a. Is the PC/laptop you are using directly connected to the LAN port of the FVS318N?
    b. What browser are you using to access the web-GUI of the FVS318N?
    c. Have you tried using other browsers like Firefox or Safari to upgrade the firmware of the FVS318N via its web-GUI?
    d. Have you tried using other PC/laptop to upgrade the firmware of the FVS318N either via its web-GUI or via telnet?
    e. Have you tried downloading the firmware v4.3.5-3 again then tried to proceed with the firmware upgrade either via web-GUI or telnet?
    f. Have you tried to reboot the FVS318N then try again to upgrade the firmware to v4.3.5-3?
    g. What is the current firmware version of your FVS318N?
    DaneA
    NETGEAR Community Team
  • Hello,
    (a) yes
    (b) google chrome and microsoft edge
    (c) I haven't tried safari or firefox
    (d) no, I currently have only 1 pc with an ethernet port
    (e) yes
    (f) yes
    (g) 4.3.4-2
    Thanks for the help!
    • DaneA's avatar
      DaneA
      lumandryk,
      Thanks for the feedback.  I suggest you to try to clear the cache of the browser(s) you are using as well as try using other browsers like Firefox in upgrading the firmware via the web-GUI of the FVS318N.
      DaneA
      • lumandryk's avatar
        lumandryk
        Just tried upgrading the firmware via web-gui in firefox (freshly installed) and as expected it didn't work, said that the firmware was invalid or corrupted. FWIW I also tried installing previous versions, from the very same files that worked in the past, all failed in the same way. I also tried the telnet route, unsuccessfully as well.
        Any other suggestions? Is there a way to force installation and bypass all validation?
        Thanks!
ProSupport for Business
