externaluse
Dec 21, 2016Aspirant
Fritz Box 7490 to SRX5308 - VLAN over VPN
Hi, I hope you can help me. I've got a business network with an SRX5308, and home office with an AVM Fritz Box 7490. On the business side, I've got VLAN Default 10.0.0.0/24 VLAN 72 192.68.72.0/...
- Jan 10, 2017
Now I get what you wanted to accomplish: from Site A === passing through ===> MainSite === going to ===> Site B is not possible. It would be best if you just configure a VPN connection directly between Site A and Site B.
DaneA
NETGEAR Community Team
externaluse
Jan 10, 2017Aspirant
Hi DaneA
this is almost right, with the exception of only 1 (main) WAN port being used. WAN 2 is only a failover for the 100 Mbps line on WAN1. So all Tunnels terminate on WAN1.
VLAN 72 (192.168.72.0/24) is defined next to the default VLAN 10.0.0.0/24 on Main Site, and accessed from Site A, which is 192.168.178.0/24. This is working fine using your suggestion.
What I was wondering is if it is possible to access the tunnels (and if so, how) like this:
Site A to Site B via Main Site. It's been a little while, but I think I tried:
- Duplicating the working VPN policies from Site A to Main with a target network of 192.168.55.0
- Duplicating the working VPN policy from Site B to Main Site, with a target network of 192.168.178.0/24 (Site A).
That didn't seem to work as easily as accessing the VLAN from Site A.
DaneA
Jan 10, 2017NETGEAR Employee Retired
DaneA
- externaluseJan 10, 2017Aspirant
That's a pity - you're certain I reckon...
Problem is that Site A isn't allowed to connect to the other endpoints directly from a dynamic IP range. The only aggressive mode we have is for the main site.
Looks as though I will have to figure out something else.
Thanks for your time anyway!
- DaneAJan 10, 2017NETGEAR Employee Retired
You're welcome! :) Feel free to post your future concerns here in the community.
Cheers,
DaneA
NETGEAR Community Team - chrbusJan 25, 2017Aspirant
Hello everybody.
I am new here and I am also interested in connecting our SRX5308 with a Fritzbox 7490.However, oit is realy difficult to find information about how a configuration file of the netgear for a Fritzbox looks like.
Is there any sample config file, which i could fit to our busines network?
Hope the question is not wrong or stupid.
Best Regards and Thanks1
Chris
- externaluseJan 25, 2017Aspirant
Hi Chrbus
I'm happy to share my experience. You may want to post this in a new topic to keep it tidy. Reply here with the link to the newly created topic so others may find it.
that sounds great!! thank you very much
I have created a new post:
best regards
chris
