MCFH1
May 16, 2017Tutor
FS336Gv3 IPv6 Implemementation Issues
I thought I should post with an update on around 12 months of discussion with Netgear Support and my ISP (Zen Internet). The FVS336Gv3 router implements IPv6 with a dual session approach not a du...
DaneA
May 25, 2017NETGEAR Employee Retired
Since you were able to get in touch with NETGEAR Support, I believe your concern has been raised to the engineering team. However, you may want to post your concern as a request in the Idea Exchange for Business here so that the development team can see what should be changed or be implemented on the FVS336Gv3. Be reminded that the more kudos given by community members to your request will help as the development team will be reviewing the post that has the most kudos and might be considered.
DaneA
NETGEAR Community Team
diepes
Jul 29, 2017Aspirant
Does this mean there is no Netgear support for IPv6 ISP's ?
My isp: BigPipe@New Zealand.
Are there any links on how to troubleshoot Netgear IPv6 issues ?
- MCFH1Jul 30, 2017TutorIf they are following the above standard - yes.... can you ask your ISP if they do
My view is Netgear needs to change - whether they will who knows... I am probably going to switch to a different manufacturer as they are giving me no confidence and are about the only vendor not in that consortium
Regards
Mark
