simstars
Oct 18, 2017Aspirant
FSV318N connection drop and kernel emergencies and errors in log
Here are some of the messages that appear on my syslog server: [Kernel] Should overwrite TID here for NULL data [Kernel] xt_TCPMSS: bad length (589 bytes) [Kernel] <sppe_cmd_arp> Fail to delete IP...
JohnC_V
Oct 19, 2017NETGEAR Employee Retired
Hi simstars,
Welcome to our community!
It seems that you were having issues with arp table. Have you tried to enable/disable the arp broadcast? Go to Network Configuration > LAN Setup - Advanced(Upper right corner) - Enable ARP Broadcast then hit Apply.
- simstarsOct 19, 2017Aspirant
it's on by default. Disabling it seems not like a solution to me. Seems like a workaround.
and what about the other two messages:
especially the first one does appear a lot in the log.
- simstarsOct 20, 2017Aspirant
similar case: https://community.netgear.com/t5/VPN-Firewalls/fvs318-drop-wireless/m-p/1359223
similar logs.
- JohnC_VOct 20, 2017NETGEAR Employee Retired
simstars,
Yes, you are correct. That is just part of our workaround to see if that would work. You may also try to flash the firmware.
- simstarsOct 26, 2017Aspirant
I have had this issue with older firmware builds too.
Have just received a mail from the forum with a lot of empty placeholders
