simstars
Oct 18, 2017Aspirant
FSV318N connection drop and kernel emergencies and errors in log
Here are some of the messages that appear on my syslog server: [Kernel] Should overwrite TID here for NULL data [Kernel] xt_TCPMSS: bad length (589 bytes) [Kernel] <sppe_cmd_arp> Fail to delete IP...
JohnC_V
Oct 19, 2017NETGEAR Employee Retired
Hi simstars,
Welcome to our community!
It seems that you were having issues with arp table. Have you tried to enable/disable the arp broadcast? Go to Network Configuration > LAN Setup - Advanced(Upper right corner) - Enable ARP Broadcast then hit Apply.
simstars
Oct 19, 2017Aspirant
it's on by default. Disabling it seems not like a solution to me. Seems like a workaround.
and what about the other two messages:
especially the first one does appear a lot in the log.
