simstars
Oct 18, 2017Aspirant
FSV318N connection drop and kernel emergencies and errors in log
Here are some of the messages that appear on my syslog server: [Kernel] Should overwrite TID here for NULL data [Kernel] xt_TCPMSS: bad length (589 bytes) [Kernel] <sppe_cmd_arp> Fail to delete IP...
JohnC_V
Oct 19, 2017NETGEAR Employee Retired
Hi simstars,
Welcome to our community!
It seems that you were having issues with arp table. Have you tried to enable/disable the arp broadcast? Go to Network Configuration > LAN Setup - Advanced(Upper right corner) - Enable ARP Broadcast then hit Apply.
simstars
Oct 20, 2017Aspirant
similar case: https://community.netgear.com/t5/VPN-Firewalls/fvs318-drop-wireless/m-p/1359223
similar logs.
