simstars
Oct 18, 2017Aspirant
FSV318N connection drop and kernel emergencies and errors in log
Here are some of the messages that appear on my syslog server: [Kernel] Should overwrite TID here for NULL data [Kernel] xt_TCPMSS: bad length (589 bytes) [Kernel] <sppe_cmd_arp> Fail to delete IP...
simstars
Oct 20, 2017Aspirant
similar case: https://community.netgear.com/t5/VPN-Firewalls/fvs318-drop-wireless/m-p/1359223
similar logs.
JohnC_V
Oct 20, 2017NETGEAR Employee Retired
simstars,
Yes, you are correct. That is just part of our workaround to see if that would work. You may also try to flash the firmware.
