simstars
Oct 18, 2017Aspirant
FSV318N connection drop and kernel emergencies and errors in log
Here are some of the messages that appear on my syslog server: [Kernel] Should overwrite TID here for NULL data [Kernel] xt_TCPMSS: bad length (589 bytes) [Kernel] <sppe_cmd_arp> Fail to delete IP...
simstars
Oct 26, 2017Aspirant
I have had this issue with older firmware builds too.
Have just received a mail from the forum with a lot of empty placeholders
JohnC_V
Oct 27, 2017NETGEAR Employee Retired
I'm afraid that this placeholders is not coming from the firewall itself. Have you tried connecting it to another router just to isolate?
- simstarsOct 30, 2017Aspirant
lol, no the empty placeholders are in the mail I received from this netgear community forum.
I have replaced the router before with a 336 prosafe I believe. Connection dropped too. I thought it could be the combination of the modem with the prosafe product line. But we moved from fiber optic to cable internet and that did not solve it too.
- JohnC_VNov 03, 2017NETGEAR Employee Retired
simstars,
Have you tried to check that same email on other network and check if will show the same thing? May I know who is your ISP?
- simstarsNov 05, 2017Aspirant
it's not about the email which I received from this netgear community forum with the empty placeholders.
it's about the logs from the fvs318n router/firewall/vpn which has red errors and red emergencys listed.
I have contacted Netgear about it and they say: the product is out of support since september https://www.netgear.com/support/product/fvs318n.aspx
so there is no support for the errors etc. even though I have had them for ages. Even before I switched ISP's
I moved from fiber optic to cable dsl and had (the same) issues with both.
Seems disabling the by default enabled udp/tcp flood fixes the connection drops.
