Tynendir
Jun 25, 2014Aspirant
FVG318 and Youtube
Hi,
I've recently purchased a FVG318 (my guess would be it's a v1 as there is no hint that there was a previous version on the box) in order to have a strong long range wifi signal. Everything was working but apparently the firmware we had was unstable (it was disconnecting evry now and then and from time to time we had no internet) and we upgraded it. Since then no problem except one. We now can't connect to Youtube. I am almost certain it comes from the FVG318 as it works when i plug in directly to the modem but it doesn't with any device connected in wifi (so it's not OS side, as I connected 2 Androids, 1 XP, 2 Vista and 2 Windows 7). Any help?
Thank you,
PS: I can't call the tech support as my device was bought second-hand. I'm quite angry about it as we in our family have bought Netgear products for more than a decade now.
Thank you,
- SamirDProdigyInteresting. That's definitely a different problem.
On the 124g, it will load the entire page, but will almost immediately state that the video is unavailable and you have to try later.
